Zum Hauptinhalt wechseln
Betty Crocker Hot Pot BC-1762 Disassembly
Was du brauchst
  1. Betty Crocker Hot Pot BC-1762 Disassembly, Betty Crocker Hot Pot BC-1762 Disassembly: Schritt 1, Bild 1 von 2 Betty Crocker Hot Pot BC-1762 Disassembly, Betty Crocker Hot Pot BC-1762 Disassembly: Schritt 1, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove the main 24 mm screw, washer, and black stopper located at the bottom of the Hot Pot.
  2. Betty Crocker Hot Pot BC-1762 Disassembly: Schritt 2, Bild 1 von 2 Betty Crocker Hot Pot BC-1762 Disassembly: Schritt 2, Bild 2 von 2
    • Pop off the dial that controls the heat setting.
  3. Betty Crocker Hot Pot BC-1762 Disassembly: Schritt 3, Bild 1 von 1
    • Remove the bottom section by sliding the dial bar backwards and out.
  4. Betty Crocker Hot Pot BC-1762 Disassembly: Schritt 4, Bild 1 von 2 Betty Crocker Hot Pot BC-1762 Disassembly: Schritt 4, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the two 13 mm screws and small metal bar that hold the two thick white wires in place.
    • These two wires combine to connect to the power cord on the outside of the device.
  5. Betty Crocker Hot Pot BC-1762 Disassembly: Schritt 5, Bild 1 von 2 Betty Crocker Hot Pot BC-1762 Disassembly: Schritt 5, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove:
    • the transparent red block
    • 11 mm screw and small washer
  6. Betty Crocker Hot Pot BC-1762 Disassembly: Schritt 6, Bild 1 von 1
    • Detach the raised metal portion by removing the 15 mm screw and washer using a Phillips #1 screwdriver.
  7. Betty Crocker Hot Pot BC-1762 Disassembly: Schritt 7, Bild 1 von 3 Betty Crocker Hot Pot BC-1762 Disassembly: Schritt 7, Bild 2 von 3 Betty Crocker Hot Pot BC-1762 Disassembly: Schritt 7, Bild 3 von 3
    • Use the Phillips #1 screwdriver to remove the four 10 mm screws and washers that hold the cross section of metal in place.
  8. Betty Crocker Hot Pot BC-1762 Disassembly: Schritt 8, Bild 1 von 3 Betty Crocker Hot Pot BC-1762 Disassembly: Schritt 8, Bild 2 von 3 Betty Crocker Hot Pot BC-1762 Disassembly: Schritt 8, Bild 3 von 3
    • Remove the last 10 mm screw and thin metal bar that are located under where the large metal plate was (put your back into it).
  9. Betty Crocker Hot Pot BC-1762 Disassembly: Schritt 9, Bild 1 von 1
    • Device Schematic
Abschluss
Aoife O'Reilly
219 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 14
Insgesamt: 217
