Zum Hauptinhalt wechseln
Bike Chain Replacement
Was du brauchst
  1. Bike Chain Replacement, Pick up the slipped chain and position: Schritt 1, Bild 1 von 1
    • Pick up the slipped chain and position it to the top of the correct gear while pedaling.
  2. Bike Chain Replacement, Release the derailleur and push the pedal forward: Schritt 2, Bild 1 von 1
    • Once the chain teeth are locked in place, slowly release the derailleur and push the pedal forward to move the back wheel.
  3. Bike Chain Replacement, Continue pedaling: Schritt 3, Bild 1 von 1
    • Continue pedaling until the rest of the chains are fit back into their original positions
    • Before you get back on your bike, shift to the lowest gear and continue pedaling. This movement should realign your chain and lock it back into place.
  4. Bike Chain Replacement, Reminder: Schritt 5, Bild 1 von 1
    • Changing gears without pedaling can cause the chain to bind up, and should be avoided.
Abschluss
Camara Dylan
121 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 146
