Einleitung
Instructions for removing/replacing the small drive belt (transaxle belt). This belt must also be removed in order to service the larger blade/spindle belt.
Was du brauchst
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a 1/2" socket or wrench to remove the two 26 mm bolts securing the rear guard to the back end of the brush cutter.
Raise and support the back end of the brush cutter—or tip it carefully onto its side—in order to access the bottom cover.
Use a 3/8” socket or wrench to remove the four 21 mm bolts securing the rear guard.
Remove the guard.
Relieve the tension on the transaxle drive belt by pressing on the back end of the tensioning arm. (Alternatively, use a pry bar on the front end of the tensioning arm, or remove the tensioning spring.)
Slip the transaxle drive belt off the drive pulley.
Free the belt by sliding it out between the transaxle pulley and the spindle belt.
Remove the transaxle drive belt.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
