Einleitung
This guide will walk you through the simple disassembly of the Bissell 3-in-1 Turbo's powerhead in order access and fully clean its brushroll. If your brushroll is very dirty or it has stopped spinning despite hearing a motor running, it might not be enough to clean it off via the opening on the bottom of the powerhead. The guide provides clear, step-by-step instructions on how to open the powerhead, remove the internal components, and re-assemble everything back in working condition.
Was du brauchst
Unhook the powerhead from the main body with the grey latch on the underside and pull to detach it.
Use Phillips #2 screwdriver to remove all eight screws on the underside of the powerhead.
Carefully separate the top and bottom halves of the powerhead.
Take note of the main components inside the powerhead: the brushroll (red), the rubber track (yellow), and the motor (blue).
Clean any dust, hair, or other debris from both the brushroll and the internal casing of the powerhead.
Reseat the brushroll into the notches it came out of.
Wrap the rubber track both around the black gear teeth on the brushroll as well as the small metal gear of the motor.
Connect the smaller end of each plastic hinge to the notches on either side of the holed half of the powerhead.
Connect the other end of each hinge to each side of the brushroll.
Lower the wheeled half of the powerhead into place and snap it shut.
Screw all screws back into the underside of the powerhead.
Plug in your vacuum to make sure everything functions properly!
1 Kommentar zur Anleitung
Your instructions were absolutely 💯 on target!!!! My Bissell works perfectly again, thanks to you!!!
