Einleitung
This guide will help you take apart the handheld vacuum using the most appropriate tools to replace the battery.
Was du brauchst
Push the silver button to disconnect the dirt dish from the handheld vacuum.
Remove the four 4 .4cm screws using your P0 screwdriver head and screwdriver.
Remove the Bissell sign to remove the two 4.4cm screws, using your P0 screwdriver head and screwdriver.
Using the metal spudger, insert and lift up to remove the frame from the body.
Move along the line and repeat on the other side.
With metal spudger remove the metal clip on both sides.
Pull device apart using great force
13 weitere Personen haben diese Anleitung absolviert.
24 Kommentare zur Anleitung
Do you have the specs for the replacement battery? Model number? Any suggested sources?
There is no replacement battery. The vacuum does have a two year warranty. If you call Bissell, they will replace the vacuum.
So why show how to take it apart if I can't replace the battery??
