Einleitung
This guide will provide steps on how to replace the release button.
Was du brauchst
Grab the handle of the handheld vacuum.
With great force, remove the handheld vacuum from the entire unit.
Remove the two 4.4cm screws using the 2.0 screw.
Using the metal spudger, insert and lift up to remove the frame from the body.
Move along the line and repeat on the other side.
