Einleitung
This is a replacement guide for the belt of the Bissell Cleanview Compact Turbo 3437F. The belt allows the brush roll to rotate while the vacuum is on, which removes dirt and debris from the surfaces below it. With a faulty or damaged belt, the brush roll will be unable to function. This guide shows you how to remove the access plate, the brush roll, and the belt from the vacuum.
Was du brauchst
Use a Phillips #1 screwdriver to remove the six 20mm screws on the bottom of the vacuum.
Abschluss
