Einleitung
This is a replacement guide for the brush roll of the Bissell Cleanview Compact Turbo 3437F. The brush roll removes debris from the surface beneath it so that it can easily be picked up by the vacuum's suction. With a faulty brush roll, the vacuum will be unable to properly pick clean surfaces. This guide shows you how to remove the access plate that holds the brush roll and how to take the brush roll out of the vacuum.
Was du brauchst
Use a Phillips #1 screwdriver to remove the six 20mm screws on the bottom of the vacuum.
