Einleitung
This is a replacement guide for the dirt tank of the Bissell Cleanview Compact Turbo 3437F. The dirt tank holds all of the dust and debris picked up by the vacuum during cleaning and contains it to be discarded in a waste container later. With a faulty or damaged dirt tank, the vacuum will be unable to properly store this waste and will nullify all of the intended functions of the device. This guide shows you how to locate the dirt tank's release button and remove it from the vacuum.
Press down on the release button of the dirt tank and lift the handle to remove it.
