Einleitung
This guide covers how to take out all the filters on the vacuum to either clean or replace them. All steps are accompanied by photos to help you through the process.
Was du brauchst
Grab hold of both the flex hose handle and the extension wand.
Pull straight out to detach the handle from the extension wand.
Hold down the lock clip to unlock the flex hose from the vacuum.
Remove the flex hose from the vacuum.
After removing hose, place vacuum on back and unclip the top compartment.
Open the compartment.
Pull the dirt collection box out of the vacuum.
Place dirt collection box to the side.
Locate the Pre-Motor Filter.
Pull the filter out by grabbing the pull tab on top.
Turn vacuum around and locate the filter cover on the bottom.
Place fingers in the opening and pull off the filter cover.
Place fingers on each tab on the Post-Motor HEPA Media Filter and pull out.
Take filter out to clean or replace.
To clean Dirt Collection Box, unlatch lid and take off.
Flip Dirt Collection Box over and locate the push tab.
Push the Dirt Cup HEPA Media Filter up to take it off.
Picture 3 Shows all the filters taken out of the vacuum.
