Zum Hauptinhalt wechseln
Bissell OptiClean Cyclonic Vacuum Filter Replacements
Was du brauchst
  1. Bissell OptiClean Cyclonic Vacuum Filter Replacements, Flex Hose with Handle: Schritt 1, Bild 1 von 2 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Flex Hose with Handle: Schritt 1, Bild 2 von 2
    • Grab hold of both the flex hose handle and the extension wand.
    • Pull straight out to detach the handle from the extension wand.
  2. Bissell OptiClean Cyclonic Vacuum Filter Replacements: Schritt 2, Bild 1 von 1
    • Locate the lock clip on the other end of the flex hose.
  3. Bissell OptiClean Cyclonic Vacuum Filter Replacements: Schritt 3, Bild 1 von 2 Bissell OptiClean Cyclonic Vacuum Filter Replacements: Schritt 3, Bild 2 von 2
    • Hold down the lock clip to unlock the flex hose from the vacuum.
    • Remove the flex hose from the vacuum.
  4. Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: Schritt 4, Bild 1 von 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: Schritt 4, Bild 2 von 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: Schritt 4, Bild 3 von 3
    • After removing hose, place vacuum on back and unclip the top compartment.
    • Open the compartment.
    • Pull the dirt collection box out of the vacuum.
  5. Bissell OptiClean Cyclonic Vacuum Filter Replacements: Schritt 5, Bild 1 von 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: Schritt 5, Bild 2 von 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: Schritt 5, Bild 3 von 3
    • Place dirt collection box to the side.
    • Locate the Pre-Motor Filter.
    • Pull the filter out by grabbing the pull tab on top.
  6. Bissell OptiClean Cyclonic Vacuum Filter Replacements: Schritt 6, Bild 1 von 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: Schritt 6, Bild 2 von 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: Schritt 6, Bild 3 von 3
    • Turn vacuum around and locate the filter cover on the bottom.
    • Place fingers in the opening and pull off the filter cover.
    • Place fingers on each tab on the Post-Motor HEPA Media Filter and pull out.
  7. Bissell OptiClean Cyclonic Vacuum Filter Replacements: Schritt 7, Bild 1 von 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: Schritt 7, Bild 2 von 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: Schritt 7, Bild 3 von 3
    • Take filter out to clean or replace.
    • To clean Dirt Collection Box, unlatch lid and take off.
  8. Bissell OptiClean Cyclonic Vacuum Filter Replacements: Schritt 8, Bild 1 von 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: Schritt 8, Bild 2 von 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: Schritt 8, Bild 3 von 3
    • Flip Dirt Collection Box over and locate the push tab.
    • Push the Dirt Cup HEPA Media Filter up to take it off.
    • Picture 3 Shows all the filters taken out of the vacuum.
Abschluss
Cal Poly, Team S12-G1, Banghart Winter 2018 Mitglied von Cal Poly, Team S12-G1, Banghart Winter 2018
CPSU-BANGHART-W18S12G1
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 752
