Einleitung
Occasionally, the motorized brush can stop functioning due to a failure in the belt. This guide shows how to replace the belt inside the motorized brush.
Was du brauchst
Use a spudger or a coin to turn the circular lock clockwise to unlock the brush roll.
Remove the lock cover.
Grab the new belt and slide it on to the two gears.
Place the motor assembly back into the motorized brush enclosure.
To reassemble your device, follow the motorized brush disassembly instructions in reverse order.
