Zum Hauptinhalt wechseln
Bissell Pet Hair Eraser Vacuum Motor Replacement
Was du brauchst
  1. Bissell Pet Hair Eraser Vacuum Motor Replacement, Dirt Cup: Schritt 1, Bild 1 von 2 Bissell Pet Hair Eraser Vacuum Motor Replacement, Dirt Cup: Schritt 1, Bild 2 von 2
    • Firmly grasp the handle and press the release button.
    • Gently pull the dirt cup down and away from the vacuum body.
  2. Bissell Pet Hair Eraser Vacuum Motor Replacement, Power Button: Schritt 2, Bild 1 von 2 Bissell Pet Hair Eraser Vacuum Motor Replacement, Power Button: Schritt 2, Bild 2 von 2
    • Remove the six 1.2 mm Philips #2 screws from the handle and base.
  3. Bissell Pet Hair Eraser Vacuum Motor Replacement: Schritt 3, Bild 1 von 2 Bissell Pet Hair Eraser Vacuum Motor Replacement: Schritt 3, Bild 2 von 2
    • Grasp each half of the body and gently pull apart.
    • The green handle, power button, charge light lens, and dirt cup release are not fastened in place.
    • Once the case is split apart these items may come dislodged.
  4. Bissell Pet Hair Eraser Vacuum Motor Replacement: Schritt 4, Bild 1 von 3 Bissell Pet Hair Eraser Vacuum Motor Replacement: Schritt 4, Bild 2 von 3 Bissell Pet Hair Eraser Vacuum Motor Replacement: Schritt 4, Bild 3 von 3
    • The power button can be removed by gently lifting it off the circuitry.
  5. Bissell Pet Hair Eraser Vacuum Motor Replacement, Motherboard: Schritt 5, Bild 1 von 2 Bissell Pet Hair Eraser Vacuum Motor Replacement, Motherboard: Schritt 5, Bild 2 von 2
    • Remove the battery plastic hold down by lifting it off the tabs.
    • Remove the battery by lifting straight up.
    • Position the battery aside.
  6. Bissell Pet Hair Eraser Vacuum Motor Replacement: Schritt 6, Bild 1 von 3 Bissell Pet Hair Eraser Vacuum Motor Replacement: Schritt 6, Bild 2 von 3 Bissell Pet Hair Eraser Vacuum Motor Replacement: Schritt 6, Bild 3 von 3
    • Grasp the charger port and remove it by lifting it straight out of the case.
    • Set the charger port next to the battery.
  7. Bissell Pet Hair Eraser Vacuum Motor Replacement: Schritt 7, Bild 1 von 2 Bissell Pet Hair Eraser Vacuum Motor Replacement: Schritt 7, Bild 2 von 2
    • Remove the power button and charge LED light by gently pulling straight out of the case.
    • The vacuum motor can be removed by pulling straight out of the case.
    • All internals are now removed.
    • Set the case halves aside.
  8. Bissell Pet Hair Eraser Vacuum Motor Replacement: Schritt 8, Bild 1 von 1
    • Remove the two 1 mm Phillips #2 screws in the shown locations.
  9. Bissell Pet Hair Eraser Vacuum Motor Replacement: Schritt 9, Bild 1 von 2 Bissell Pet Hair Eraser Vacuum Motor Replacement: Schritt 9, Bild 2 von 2
    • Disconnect the power leads from the vacuum motor.
    • The red power lead goes on the terminal with the visible red dot.
  10. Bissell Pet Hair Eraser Vacuum Motor Replacement, Vacuum Motor: Schritt 10, Bild 1 von 2 Bissell Pet Hair Eraser Vacuum Motor Replacement, Vacuum Motor: Schritt 10, Bild 2 von 2
    • Grasp the vacuum motor and housing and pull them apart.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 21
Insgesamt: 1,141
