Zum Hauptinhalt wechseln
Bissell Powerglide Cordless Debris Canister Funnel Replacement
Was du brauchst
  1. Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: Schritt 1, Bild 1 von 3 Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: Schritt 1, Bild 2 von 3 Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: Schritt 1, Bild 3 von 3
    • Remove the gray motor unit by twisting it so that the black triangle moves from the "locked" to the "unlocked" position.
  2. Bissell Powerglide Cordless Debris Canister Funnel Replacement: Schritt 2, Bild 1 von 1
    • Remove the filter from the dirt canister.
  3. Bissell Powerglide Cordless Debris Canister Funnel Replacement, Debris Canister Funnel: Schritt 3, Bild 1 von 1
    • Separate the cyclone assembly from the dirt tank by twisting the pieces counterclockwise.
  4. Bissell Powerglide Cordless Debris Canister Funnel Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips head screwdriver to remove the three screws from the bottom of the cyclone assembly.
    • Remove the bottom of the assembly.
  5. Bissell Powerglide Cordless Debris Canister Funnel Replacement: Schritt 5, Bild 1 von 2 Bissell Powerglide Cordless Debris Canister Funnel Replacement: Schritt 5, Bild 2 von 2
    • Twist the clear plastic capsule with the fins counterclockwise to remove it.
  6. Bissell Powerglide Cordless Debris Canister Funnel Replacement: Schritt 6, Bild 1 von 1
    • Twist the blue parts counterclockwise with a good amount of force to remove them.
Abschluss
Cal Poly, Team S21-G2, Banghart Winter 2018 Mitglied von Cal Poly, Team S21-G2, Banghart Winter 2018
CPSU-BANGHART-W18S21G2
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 208
