Zum Hauptinhalt wechseln
Bissell SmartClean 1605 Roller Brush Replacement
Was du brauchst
  1. Bissell SmartClean 1605 Roller Brush Replacement, Roller Brush: Schritt 1, Bild 1 von 1
    • Make sure your device is powered off.
  2. Bissell SmartClean 1605 Roller Brush Replacement: Schritt 2, Bild 1 von 1
    • Gently flip device over.
  3. Bissell SmartClean 1605 Roller Brush Replacement: Schritt 3, Bild 1 von 3 Bissell SmartClean 1605 Roller Brush Replacement: Schritt 3, Bild 2 von 3 Bissell SmartClean 1605 Roller Brush Replacement: Schritt 3, Bild 3 von 3
    • Remove plastic plate cover to reveal brush roller.
  4. Bissell SmartClean 1605 Roller Brush Replacement: Schritt 4, Bild 1 von 2 Bissell SmartClean 1605 Roller Brush Replacement: Schritt 4, Bild 2 von 2
    • Remove brush roller from its slots on either side.
    • Apply pressure to one side and pull the roller out of its opposite slot.
    • It's like taking out a spring loaded toilet paper holder.
Abschluss
Austin Maranville
117 Reputation
1 Anleitung geschrieben
Cal Poly, Team S7-G4, Banghart Fall 2017 Mitglied von Cal Poly, Team S7-G4, Banghart Fall 2017
CPSU-BANGHART-F17S7G4
5 Mitglieder
5 Anleitungen geschrieben
13 Kommentare
What if mine don't feel spring loaded and the brushe seems like it was just wants to fall out
Brian - Antwort
I'm having the same issue. The spring is not reloading to the brush just falls out
Rachel -
Same issue with mine. Took it apart and found that the side with spring loaded holder was broken.
Ryan Beaudre - Antwort
I am having the same issue it’s like a part is missing for the pin side not the square sides to hold the brush roll in place.
Geoffrey Fraser - Antwort
I have the same issue…it seems that the spring part was lost.have anyone of you find a replacement parts?
Mazinger Z - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 16
Insgesamt: 1,031
