Einleitung
This is a guide on how to replace the spiral brushing system on a bissell spotbot pet. Use this if your spiral brushing system is not working properly.
Was du brauchst
Lift the tap on top of the vacuum, and then remove the container on the left side of the vacuum.
Remove the motherboard from the top piece. Repair or replace the motherboard if it is faulty.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
