Einleitung
In this guide I show you how to replace the Hose & Cuff Assembly on a Bissell SpotBot Pet carpet cleaner. Mine was left in storage for a while so the hose was very nasty so I decided to just replace it with a new one.
Was du brauchst
Remove top cover. Unplug ribbon cable from control board and set top aside.
Locate end of clear rubber tubing and remove clamp with pliers. It is nearly impossible to get the hose end off of the hose barb, so I just cut the hose close to the barb, then gently scored the tubing left on the barb to get it off.
Remove hose assembly by gently twisting up on hose. This end is just snug-fit with 2 O-Rings.
Install new hose assembly by adding a little silicone-based grease on the 2 o-rings and inserting the hose end into the hole by the waste tank inlet port. Then attatch the clear tubing on the barb, then replace the hose clamp.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
8 Kommentare
Thanks Tim! You made that very easy and straight forward. I was done in 10 minutes.
Not a problem, glad it worked for you! Mine is still going strong after 2 years.
Worked like a charm. You had very good pictures and easy to understand explanation
This is great thanks! I got as far removing the clamps and was afraid to move forward, my replacement hose did not come with new clamps and I am worried I will break them. This is my first time working with clamps. I searched the internet and found your site. This is wonderful, thank you very much.
Breathed new life into our SpotBot with these instructions, thank you!!
