Einleitung
Is your Bissell SpotClean ProHeat 5207U not spraying water? It could be because of a failing water pump. Follow this guide to replace the water pump for your Bissell SpotClean ProHeat 5207U.
Was du brauchst
Remove the marked 19.7 mm screws on the underside of the device using the Phillips #00 screwdriver.
Remove the plastic top located where the dirty water tank was previously situated.
Using the Phillips #00 screwdriver, unscrew the three 17.2 mm screws.
Remove the plastic lip that was previously held by the screws.
Using pliers, pinch the hose clamp tabs together, then remove the clamp.
Remove the water hose from the water pump.
Remove the zip tie from the water pump.
Replace the old water pump with the new water pump.
2 weitere Personen haben diese Anleitung absolviert.
