Einleitung
If any issues are arising inside your Bissell Zing 2156A, or you simply want to replace the casing, this guide will assist in taking it apart.
The casing is a extruded plastic shell, with other smaller plastic bits coming out of it. The casing is held in place by screws and small "snap-fit" fasteners. This guide starts with the removal of the rear wheel.
Overall, this assembly is safe to disassemble and reassemble.
Was du brauchst
Remove the dust tank, so the vacuum can lie upside down easily.
Press the grey button while pulling up.
Place your hand inside between the wheel and vacuum and pry the wheel off.
Repeat with the other side.
Remove the two 18.1 mm screws using a Phillips #0 screwdriver.
Remove the four 18.1 mm screws under the wheels using a Phillips #0 screwdriver.
Use the spudger to loosen the top case from the bottom. Make sure to loosen it all around the bottom and lift up.
Eine weitere Person hat diese Anleitung absolviert.
