Zum Hauptinhalt wechseln
Black and Decker 3-Cup Rice Cooker Button Mechanism Repair
Was du brauchst
    1. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Remove the Lid and Bowl: Schritt 1, Bild 1 von 1
      • Make sure the device is unplugged before beginning disassembly!
      • Lift the lid and bowl from the top of the device.
      Frag FixBot
      Kommentar hinzufügen
    2. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Turn the Device Upside-Down: Schritt 2, Bild 1 von 1
      • Turn the device upside-down, so that the four legs of the device point upwards.
      Frag FixBot
    3. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Remove the Rubber Cushions: Schritt 3, Bild 1 von 2 Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Remove the Rubber Cushions: Schritt 3, Bild 2 von 2
      • Each of the four legs has a rubber cushion on its bottom. For each cushion, insert a plastic opening tool between the plastic leg and rubber cushion, and pry off the rubber cushion.
      Frag FixBot
    4. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Remove the Spanning Screw: Schritt 4, Bild 1 von 1
      • Using a spanner screwdriver, remove the one 10mm long 7mm diameter spanner screw from the side of the brass panel.
      Frag FixBot
    5. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Remove the Leg Screws: Schritt 5, Bild 1 von 1
      • Using a Phillips screwdriver, remove the 10mm long 7mm diameter Phillips-head screws from the inside of all four legs.
      • The smaller leg at the bottom is now loose and not attached to the device. Set it aside.
      Frag FixBot
    6. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Remove the Brass Plate: Schritt 6, Bild 1 von 1
      • Lift the brass plate off the device and set it aside.
      Frag FixBot
    7. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Color the Wires: Schritt 7, Bild 1 von 2 Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Color the Wires: Schritt 7, Bild 2 von 2
      • Color coordinating wire groups make it easier to identify the wire groups during reassembly.
      • Inside the device, there are three junctions with wires joined by Phillips-head screws. The first is connected to two wires, and the other two are connected to three wires each.
      • Unscrew the screw at the junction near the opposite side of the device from the front panel.
      • Label each of the two wires at this junction with a single color of tape.
      Frag FixBot
    8. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Label the Second Wire Junction: Schritt 8, Bild 1 von 2 Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Label the Second Wire Junction: Schritt 8, Bild 2 von 2
      • Unscrew the screw at the junction just clockwise from the button panel.
      • Label the three wires of this junction with tape of a second color.
      Frag FixBot
    9. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Label the Third Wire Junction: Schritt 9, Bild 1 von 2 Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Label the Third Wire Junction: Schritt 9, Bild 2 von 2
      • Unscrew the screw from the wire junction just behind the front panel.
      • Label the three wires at this junction with a third color of tape.
      Frag FixBot
    1. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Check the Locking Beam: Schritt 10, Bild 1 von 1
      • On the inside of the device, there is a silver-colored beam leading to the center with a U-shaped brass beam poking through it.
      • The U-shaped brass beam should be bent outwards so that it cannot fit through the hole in the silver-colored beam.
      Frag FixBot
    2. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Position the Brass Beam: Schritt 11, Bild 1 von 2 Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Position the Brass Beam: Schritt 11, Bild 2 von 2
      • If the brass beam is not poking through the silver-colored beam, you will need to position it so that it is.
      • Position the brass beam below the hole in the silver-colored beam and push the silver-colored beam into it, so that the brass beam pokes through.
      Frag FixBot
    3. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Bend the Brass Beam: Schritt 12, Bild 1 von 1
      • If the brass beam can't fit through the hole in the silver-colored beam, use pliers to bend the brass beam outwards so that it does not fit through the hole in the silver-colored beam.
      Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 12-1, Forte Fall 2014 Mitglied von Cal Poly, Team 12-1, Forte Fall 2014
CPSU-FORTE-F14S12G1
5 Mitglieder
14 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 33
Insgesamt: 3,466
