Einleitung
In this guide we will show step by step to replace the main circuit board within the device. The circuit board takes power from the chord and sends it to the trigger and motor. Any number of things could cause the circuit board from failing such as faulty wiring, to water entering the device. This guide is pretty simple and can be done in only four major steps.
Was du brauchst
To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
Leaving your finger pressed down on the button, simply pull on the attachment to release it.
Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
There will be one black wire, a thin white wire and a thin red wire connecting to the trigger module from the circuit board. Using your needle nose tweezers insert one of the ends into the release slot below the white wire.
Lift the end of the tweezers to release the wire.
The Circuit board is now free.
