Einleitung
Prerequisite Only - Identifying and unscrewing all screws that keep the armature together.
Was du brauchst
To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
Leaving your finger pressed down on the button, simply pull on the attachment to release it.
Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
