Zum Hauptinhalt wechseln
Black and Decker BDEDMT Power Cord Replacement
Was du brauchst
  1. Black and Decker BDEDMT Power Cord Replacement, Detach Matrix Attachment: Schritt 1, Bild 1 von 2 Black and Decker BDEDMT Power Cord Replacement, Detach Matrix Attachment: Schritt 1, Bild 2 von 2
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: Schritt 2, Bild 1 von 3 Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: Schritt 2, Bild 2 von 3 Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: Schritt 2, Bild 3 von 3
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Power Cord Replacement, Mounting Bracket: Schritt 3, Bild 1 von 2 Black and Decker BDEDMT Power Cord Replacement, Mounting Bracket: Schritt 3, Bild 2 von 2
    • Using the T-handle screwdriver with the JIS 1 bit, unscrew the two lower black 12mm screws.
  4. Black and Decker BDEDMT Power Cord Replacement: Schritt 4, Bild 1 von 2 Black and Decker BDEDMT Power Cord Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • There will be a white cord that runs from the power cord base to the circuit board located slightly above.
    • Use the tweezers to detach the entire white cord and blue connection piece as a whole from the circuit board.
  5. Black and Decker BDEDMT Power Cord Replacement, Trigger Assembly: Schritt 5, Bild 1 von 2 Black and Decker BDEDMT Power Cord Replacement, Trigger Assembly: Schritt 5, Bild 2 von 2
    • Physically pull up on the trigger device and remove it from the armature.
    • Flip trigger device over onto its back.
  6. Black and Decker BDEDMT Power Cord Replacement, Wire Removal: Schritt 6, Bild 1 von 3 Black and Decker BDEDMT Power Cord Replacement, Wire Removal: Schritt 6, Bild 2 von 3 Black and Decker BDEDMT Power Cord Replacement, Wire Removal: Schritt 6, Bild 3 von 3
    • There is a screw labeled 3 located on the bottom left of the back of the trigger device.
    • Use a JIS 0 screwdriver to remove screw.
    • Gently tug on the black wire to pull the wire out of the device.
    • Now the power cord will be completely removed from the device.
Abschluss
cayla dahl
247 Reputation
2 Anleitungen geschrieben
UW Tacoma, Team 1-2, Rose Winter 2016 Mitglied von UW Tacoma, Team 1-2, Rose Winter 2016
UWT-ROSE-W16S1G2
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 33
Insgesamt: 2,177
