Einleitung
This guide describes how to replace the power button from the BLACK and DECKER BDERO100 5 inch sander. The tools that you will need for this process are the TR20 Torx Security bit driver or equivalent, the nylon spudger & the plastic opening tool
Was du brauchst
Use the nylon spudger to remove the rubber ring from the filter attachment section.
Use the TR20 Torx Security bit driver to unscrew the five 18.75mm Phillips screws from the warning label side of the chassis.
Grab the plastic opening tool and place it on the separation line between both sides of the chassis.
Separate both sides and open the device.
Push the security pin with the plastic spudger and simultaneously, pull gently on the cable to separate it from the button
Detach the black wire connected to the power button from the motor. To do this, gently pull the cable while holding the power button.
