Einleitung
This guide provides information on how to remove and replace the Power Cord of the BLACK and DECKER BDERO100 5 inch sander. The tools that you will need for this process is the JIS - J1 bit driver or equivalent, the TR20 Torx Security bit driver or equivalent, the plastic spudger & the plastic opening tool.
Was du brauchst
Use the nylon spudger to remove the rubber ring from the filter attachment section.
Use the TR20 Torx Security bit driver to unscrew the five 18.75mm Phillips screws from the warning label side of the chassis.
Grab the plastic opening tool and place it on the separation line between both sides of the chassis.
Separate both sides and open the device.
Use the bit driver with the JIS - J1 bit to remove the two 12.5 mm phillips screws holding the cord clamp to the chassis.
Gently pull the white cable that connects the power cord to the motor to detach it.
With yout hands, hold and separate the power button from the external case by pulling gently.
Push the security pin with the plastic spudger and simultaneously, pull gently on the cable to separate it from the button.
Eine weitere Person hat diese Anleitung absolviert.
