Zum Hauptinhalt wechseln
Black and Decker BDH9600CHV Motor Replacement
Was du brauchst
  1. Black and Decker BDH9600CHV Motor Replacement, Motor: Schritt 1, Bild 1 von 3 Black and Decker BDH9600CHV Motor Replacement, Motor: Schritt 1, Bild 2 von 3 Black and Decker BDH9600CHV Motor Replacement, Motor: Schritt 1, Bild 3 von 3
    • To remove the filter and housing, press the green button labeled "Filter".
  2. Black and Decker BDH9600CHV Motor Replacement: Schritt 2, Bild 1 von 1
    • Unscrew and remove all 5 screws using the Phillips 0 screw bit. Each screw is 17.5 mm long.
  3. Black and Decker BDH9600CHV Motor Replacement: Schritt 3, Bild 1 von 3 Black and Decker BDH9600CHV Motor Replacement: Schritt 3, Bild 2 von 3 Black and Decker BDH9600CHV Motor Replacement: Schritt 3, Bild 3 von 3
    • Pull the housing apart
    • When you pull apart the housing pieces could fall out. Be sure to keep track of them.
    • Remove the motor unit from the housing
    • Note that the black disk needs to be firmly pulled it will resist, but can be pulled directly off of the pin if it is pulled hard enough.
  4. Black and Decker BDH9600CHV Motor Replacement: Schritt 4, Bild 1 von 3 Black and Decker BDH9600CHV Motor Replacement: Schritt 4, Bild 2 von 3 Black and Decker BDH9600CHV Motor Replacement: Schritt 4, Bild 3 von 3
    • Remove the motor from the circuit board.
    • The motor makes contact with the board at 2 points. These may be bent or distorted. Straighten them with a pair of needle nose pliers in order to remove.
Abschluss
Ivette Muzquiz
349 Reputation
3 Anleitungen geschrieben
IUPUI, Team S1-G4, Harley Fall 2017 Mitglied von IUPUI, Team S1-G4, Harley Fall 2017
IUPUI-HARLEY-F17S1G4
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 17
Insgesamt: 2,313
