Einleitung
Upon completion of this guide, you can successfully install and replace the motor fan for you blender.
Was du brauchst
Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
Remove the following screws that secure the top and bottom halves of the base.
One 1/4 Phillips screw
One TA-20 screw
Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
mon mixeur a montre des itincelles et de la fumeé quel étape puis suivre pour le réparer
