Zum Hauptinhalt wechseln
Black and Decker BL3000S Motor Fan Replacement
Was du brauchst
  1. Black and Decker BL3000S Motor Fan Replacement, Blender Base: Schritt 1, Bild 1 von 2 Black and Decker BL3000S Motor Fan Replacement, Blender Base: Schritt 1, Bild 2 von 2
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Black and Decker BL3000S Motor Fan Replacement: Schritt 2, Bild 1 von 1
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Black and Decker BL3000S Motor Fan Replacement: Schritt 3, Bild 1 von 2 Black and Decker BL3000S Motor Fan Replacement: Schritt 3, Bild 2 von 2
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Black and Decker BL3000S Motor Fan Replacement: Schritt 4, Bild 1 von 1
    • Remove the following screws that secure the top and bottom halves of the base.
    • One 1/4 Phillips screw
    • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. Black and Decker BL3000S Motor Fan Replacement: Schritt 5, Bild 1 von 1
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
  6. Black and Decker BL3000S Motor Fan Replacement, Motor Fan: Schritt 6, Bild 1 von 2 Black and Decker BL3000S Motor Fan Replacement, Motor Fan: Schritt 6, Bild 2 von 2
    • Using pliers, remove the top nut from the fan and remove the washer.
    • Use a small towel to hold the fan in place. This makes taking off the nut easier to do.
  7. Black and Decker BL3000S Motor Fan Replacement: Schritt 7, Bild 1 von 1
    • Lift the fan blades from the blender base.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Andrew
209 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 6-34, Regan Fall 2012 Mitglied von Cal Poly, Team 6-34, Regan Fall 2012
CPSU-REGAN-F12S6G34
4 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
mon mixeur a montre des itincelles et de la fumeé quel étape puis suivre pour le réparer
abdelkarim hassi - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 11
Letzte 30 Tage: 56
Insgesamt: 4,451
