Einleitung
You will need to have completed the prerequisite guides prior to this guide in order to execute it.
Was du brauchst
Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
Remove the following screws that secure the top and bottom halves of the base.
One 1/4 Phillips screw
One TA-20 screw
Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
Once you have the base removed, the circuit board should be clearly visible inside.
Remove the four screws located on the circuit board.
Two are on the left side.
Two are on the right side.
Remove the following soldered connections with a soldering iron:
Motor wires
Power cord wires
Once the circuit board has been freed from its screws it can be moved out of the way to gain access to the buttons.
A single screw must be removed from the top as shown.
Push firmly from the outside of the blender on the face of the buttons to pop it out of its locked position.
Provided is a front and a back view of a functioning button frame from the BL3000S.
