Zum Hauptinhalt wechseln
Black and Decker BL3000S button panel replacement
Was du brauchst
  1. Black and Decker BL3000S button panel replacement, Blender Base: Schritt 1, Bild 1 von 2 Black and Decker BL3000S button panel replacement, Blender Base: Schritt 1, Bild 2 von 2
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Black and Decker BL3000S button panel replacement: Schritt 2, Bild 1 von 1
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Black and Decker BL3000S button panel replacement: Schritt 3, Bild 1 von 2 Black and Decker BL3000S button panel replacement: Schritt 3, Bild 2 von 2
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Black and Decker BL3000S button panel replacement: Schritt 4, Bild 1 von 1
    • Remove the following screws that secure the top and bottom halves of the base.
    • One 1/4 Phillips screw
    • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. Black and Decker BL3000S button panel replacement: Schritt 5, Bild 1 von 1
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
  6. Black and Decker BL3000S button panel replacement, Circuit Board: Schritt 6, Bild 1 von 1
    • Once you have the base removed, the circuit board should be clearly visible inside.
  7. Black and Decker BL3000S button panel replacement: Schritt 7, Bild 1 von 2 Black and Decker BL3000S button panel replacement: Schritt 7, Bild 2 von 2
    • Remove the four screws located on the circuit board.
    • Two are on the left side.
    • Two are on the right side.
  8. Black and Decker BL3000S button panel replacement: Schritt 8, Bild 1 von 1
    • Remove the following soldered connections with a soldering iron:
    • Motor wires
    • Power cord wires
  9. Black and Decker BL3000S button panel replacement: Schritt 9, Bild 1 von 1
    • Lift the circuit board straight up to remove it from the base.
  10. Black and Decker BL3000S button panel replacement, Buttons: Schritt 10, Bild 1 von 1
    • Once the circuit board has been freed from its screws it can be moved out of the way to gain access to the buttons.
    • A single screw must be removed from the top as shown.
  11. Black and Decker BL3000S button panel replacement: Schritt 11, Bild 1 von 1
    • Push firmly from the outside of the blender on the face of the buttons to pop it out of its locked position.
  12. Black and Decker BL3000S button panel replacement: Schritt 12, Bild 1 von 2 Black and Decker BL3000S button panel replacement: Schritt 12, Bild 2 von 2
    • Provided is a front and a back view of a functioning button frame from the BL3000S.
    • Check for cracks, bends, debris, or missing extentions and fastens.
Abschluss
Austin Abernathy
18 Reputation
1 Anleitung geschrieben
Cal Poly, Team 6-34, Regan Fall 2012 Mitglied von Cal Poly, Team 6-34, Regan Fall 2012
CPSU-REGAN-F12S6G34
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 2,373
