Zum Hauptinhalt wechseln
Einleitung
This guide will take you through the process of replacing the clamshell on the Black and Decker BV2500 Type 4. It is important to replace the clam shell when it is damaged, if the impellor is exposed, it can be dangerous for the operator.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
    • Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
  2. Using your hands, remove the blower tube and clamshell. To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
    • Using your hands, remove the blower tube and clamshell.
    • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
Abschluss
Angelica Chow
388 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 9-29, Maness Winter 2014 Mitglied von Cal Poly, Team 9-29, Maness Winter 2014
CPSU-MANESS-W14S9G29
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 553
