Einleitung
This lid of the coffee machine will have to be removed for most of the replacement or repairs done on the coffee maker, or even if the lid becomes damaged. These steps will provide the instructions in removing the lid.
Was du brauchst
Place your finger, screwdriver, or spudger behind the corner of the tab.
Pull up on the tab until it disconnects from the coffee maker.
Hold the tab while pushing back on the lid.
The lid should open fully with the top of the lid facing down.
Insert the flathead screwdriver or spudger into one of the inserts holding the lid.
Pry facing away from the lid to force the peg out.
Hold the lid and pull it away from the other insert.
