Zum Hauptinhalt wechseln
Black and Decker CM0700BZ Power Button Replacement
Was du brauchst
  1. Black and Decker CM0700BZ Power Button Replacement, Power Button: Schritt 1, Bild 1 von 2 Black and Decker CM0700BZ Power Button Replacement, Power Button: Schritt 1, Bild 2 von 2
    • Ensure power cord is unplugged from the wall.
    • Remove the carafe holder from the bottom of the coffee machine.
  2. Black and Decker CM0700BZ Power Button Replacement: Schritt 2, Bild 1 von 3 Black and Decker CM0700BZ Power Button Replacement: Schritt 2, Bild 2 von 3 Black and Decker CM0700BZ Power Button Replacement: Schritt 2, Bild 3 von 3
    • Place coffee maker on its side, with the bottom facing you.
    • Remove the two 10 mm Phillips #1 screws.
    • Remove one 10 mm Tri-Point Y1 screw.
  3. Black and Decker CM0700BZ Power Button Replacement: Schritt 3, Bild 1 von 3 Black and Decker CM0700BZ Power Button Replacement: Schritt 3, Bild 2 von 3 Black and Decker CM0700BZ Power Button Replacement: Schritt 3, Bild 3 von 3
    • Slowly pry the bottom lid from the front.
    • You should hear a pop.
    • Pull up and remove the bottom lid.
  4. Black and Decker CM0700BZ Power Button Replacement: Schritt 4, Bild 1 von 3 Black and Decker CM0700BZ Power Button Replacement: Schritt 4, Bild 2 von 3 Black and Decker CM0700BZ Power Button Replacement: Schritt 4, Bild 3 von 3
    • Using a screwdriver or spudger, firmly press on the middle of heat shrink and pull each electrical connection apart.
    • Gently push the power button out of the housing while pushing the tabs inwards.
  5. Black and Decker CM0700BZ Power Button Replacement: Schritt 5, Bild 1 von 3 Black and Decker CM0700BZ Power Button Replacement: Schritt 5, Bild 2 von 3 Black and Decker CM0700BZ Power Button Replacement: Schritt 5, Bild 3 von 3
    • Use a screwdriver or spudger to pry out the power button.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team 1-2, Shaddix Spring 2023 Mitglied von UMass Dartmouth, Team 1-2, Shaddix Spring 2023
UMASSD-SHADDIX-S23S1G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 19
Letzte 30 Tage: 61
Insgesamt: 640
