Zum Hauptinhalt wechseln
Black and Decker DustBuster 15.6V Nozzle Brush Replacement
Was du brauchst
  1. Black and Decker DustBuster 15.6V Nozzle Brush Replacement, Nozzle Brush: Schritt 1, Bild 1 von 1
    • Lift Nozzle Brush until it clicks into fully erect position.
  2. Black and Decker DustBuster 15.6V Nozzle Brush Replacement: Schritt 2, Bild 1 von 1
    • Apply a gentle, equal pressure outward, to the inside of both brush legs.
  3. Black and Decker DustBuster 15.6V Nozzle Brush Replacement: Schritt 3, Bild 1 von 1
    • Remove one of the leg prongs from the hole it is inserted into.
  4. Black and Decker DustBuster 15.6V Nozzle Brush Replacement: Schritt 4, Bild 1 von 1
    • Rotate the free leg forwards or backwards from the hole.
    • This relieves the pressure from the inside of the legs allowing you to freely remove the last leg from its hole.
  5. Black and Decker DustBuster 15.6V Nozzle Brush Replacement: Schritt 5, Bild 1 von 1
    • Check each leg hole for debris and clear whats needed.
    • Insert a leg of the new brush into the correct hole, so the brush will click into its erect position.
    • Slide the other leg into its respective hole.
Abschluss
Jacob
101 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S6-G1, Isaacson Spring 2017 Mitglied von UMass Dartmouth, Team S6-G1, Isaacson Spring 2017
UMASSD-ISAACSON-S17S6G1
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 354
