Einleitung
This guide shows how to disassemble your vacuum enough to remove and replace a faulty power switch. It is a fairly simple process requiring only a long neck Phillips head screwdriver.
Was du brauchst
Remove nozzle by pressing two blue buttons with unlock symbols on the side of the nozzle.
Pull the nozzle upward.
Remove the six exterior 2 mm Phillips #1 screws that secure the two halves of the outer shell.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Well, 50mm thin screw driver is also one of tool, normally people don't have it. Hence special mention of philips screw driver might help user.
