Zum Hauptinhalt wechseln
Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement
Was du brauchst
  1. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement, Suction Rubber Seal: Schritt 1, Bild 1 von 1
    • Press to blue unlock buttons at the base of the nozzle in word and pull forward .
  2. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: Schritt 2, Bild 1 von 1
    • Locate rubber suction seal.
  3. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: Schritt 3, Bild 1 von 1
    • Insert a metal spudger in between white plastic and rubber seal and gently drag spudger around see you lifting gently much like opening a can.
  4. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: Schritt 4, Bild 1 von 1
    • Align slits on the bottom of new suction seal then press into those slits.
    • The seal should not come above white plastic.
    • If the nozzle does not connect to vacuum barrel, readjust seal and try to attach nozzle until it snaps into place.
Abschluss
Roberto Perez
101 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S6-G1, Isaacson Spring 2017 Mitglied von UMass Dartmouth, Team S6-G1, Isaacson Spring 2017
UMASSD-ISAACSON-S17S6G1
4 Mitglieder
9 Anleitungen geschrieben
Ein Kommentar
Where can I buy a new suction seal.
Alison Junk - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 19
Insgesamt: 2,281
