Zum Hauptinhalt wechseln
Einleitung
In the Black and Decker CHV1510, the battery pack is one of the main components to fail. This guide will show you how to replace the battery pack in your vacuum.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: Schritt 1, Bild 1 von 2 Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: Schritt 1, Bild 2 von 2
    • Remove the six exterior 2 mm Phillips #0 screws securing the 2 halves of the white shell together.
  2. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: Schritt 2, Bild 1 von 2 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: Schritt 2, Bild 2 von 2
    • Remove nozzle by pressing two blue buttons on the side of the nozzle
  3. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: Schritt 3, Bild 1 von 2 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: Schritt 3, Bild 2 von 2
    • Remove the dustbin by pressing the blue button on the vacuum's handle and lift the bin from the vacuum.
  4. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: Schritt 4, Bild 1 von 3 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: Schritt 4, Bild 2 von 3 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: Schritt 4, Bild 3 von 3
    • Gently separate the two halves by pulling them apart, revealing the 14 cell battery pack behind the motor.
  5. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: Schritt 5, Bild 1 von 2 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: Schritt 5, Bild 2 von 2
    • Removal of the battery pack is a tool-less process, lift the battery pack out of the vacuum gently, notice there are two wires connected to the battery.
  6. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: Schritt 6, Bild 1 von 2 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the red wire from the battery pack (pull do not twist!) and do the same with the black wire
  7. Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: Schritt 7, Bild 1 von 3 Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: Schritt 7, Bild 2 von 3 Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: Schritt 7, Bild 3 von 3
    • Holding the battery pack firmly, disconnect the red and black wires from the battery pack by pulling them gently.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Miguel Vilao
364 Reputation
3 Anleitungen geschrieben
IUPUI, Team S7-G6, Baechle Fall 2017 Mitglied von IUPUI, Team S7-G6, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G6
3 Mitglieder
Ein Kommentar
The battery pack in no longer available and the 14 cells would cost more than a brand new dustbuster (Feb 25, 2021). I managed to get almost 10-years out of my CHV1510.
glenn.watkins - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 4
Letzten 7 Tage: 16
Letzten 30 Tage: 64
Insgesamt: 3,195
