Einleitung
Full Device Name: Black and Decker 3-in-1 Grill - Griddle - Waffle Maker
Model Name: G48TD
This guide aims to disassemble the device into its fundamental components.
Safety warnings:
- Do not operate on device while it is receiving power
- Be careful when bending sharp metal tabs
No special skills are required for following this guide
Was du brauchst
Use a pair of Large Needle Nosed Pliers to twist the metal tabs holding the plate housing the bottom heating element connections and remove the plate.
Use a pair of Large Needle Nosed Pliers to twist the metal tabs holding the plate housing the top heating element connections and remove the plates.
Use a 4 mm Flathead screwdriver to remove the 11.4 mm screw in the back of the thermostat housing.
Lift up the thermostat housing and detach it from the temperature control arm, then remove the washers at the end of the temperature control arm.
Remove the heating elements from their respective housings (the bottom one is not able to be removed completely as it is fused to a piece of metal).
