Einleitung
In the unfortunate case of where your black and decker jigsaw base is broken this guide is here to show you how to replace the base. This will require you to remove the existing plate and replace it. Following the guides will show you how to replace the base without damaging any other parts of the jigsaw.
Was du brauchst
Use a screwdriver to remove the first screws securing the base to the jigsaw.
Remove the second screw.
Remove the base of the jigsaw.
With the old jigsaw base off, replace it with the new base by following the steps in the reverse order.
Eine weitere Person hat diese Anleitung absolviert.
