Zum Hauptinhalt wechseln
Black and Decker JS660 Blade Holder Replacement
Was du brauchst
  1. Black and Decker JS660 Blade Holder Replacement, Base: Schritt 1, Bild 1 von 2 Black and Decker JS660 Blade Holder Replacement, Base: Schritt 1, Bild 2 von 2
    • Unscrew the eight screws to open up the jigsaw.
  2. Black and Decker JS660 Blade Holder Replacement: Schritt 2, Bild 1 von 1
    • Use a screwdriver to remove the first screws securing the base to the jigsaw.
    • Remove the second screw.
    • Remove the base of the jigsaw.
  3. Black and Decker JS660 Blade Holder Replacement: Schritt 3, Bild 1 von 2 Black and Decker JS660 Blade Holder Replacement: Schritt 3, Bild 2 von 2
    • With the old jigsaw base off, replace it with the new base by following the steps in the reverse order.
    • Assemble the base on a steady surface.
  4. Black and Decker JS660 Blade Holder Replacement, Blade Holder: Schritt 4, Bild 1 von 2 Black and Decker JS660 Blade Holder Replacement, Blade Holder: Schritt 4, Bild 2 von 2
    • You will need to take out the entire blade clamp shown.
    • The plastic part is fragile, easy to break
  5. Black and Decker JS660 Blade Holder Replacement: Schritt 5, Bild 1 von 3 Black and Decker JS660 Blade Holder Replacement: Schritt 5, Bild 2 von 3 Black and Decker JS660 Blade Holder Replacement: Schritt 5, Bild 3 von 3
    • Showing the entire blade clamp removed from the device.
    • Apply some oil grease if dry/needed
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Andrew Khouri
468 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 6-2, Eyestone Spring 2016 Mitglied von USF Tampa, Team 6-2, Eyestone Spring 2016
USFT-EYESTONE-S16S6G2
4 Mitglieder
2 Kommentare zur Anleitung
What a great website… I could never have known how to replace the blade holder… Or that I could get the correct parts…I got the replacement part. Then removed the old one, and replaced the new one. NO problem at all.. Thanks to Andrew and this website… With out it, would have to pay some one at a big price, and wait to have it fixed, as would have to send it off for the repair.. Or….. Just throw it away…
Thanks every one… I will share this site for sure…
navy1aedon - Antwort
Your image titled "OLtArEqZITeHNOGW" shows the top of the blade clamp in which a rectangular bar which has a hole in it and is split by a piece of metal is in the same slot as the reticulating blade mechanism. THIS IS IMPOSSIBLE. I know this because I was dumb enough to follow this model. When you spin the fly wheel by hand, you'll see that this bar in the space where you overtly show it actually blocks the movement up and down. This damages the entire device. As a repair medium, please don't showcase feature images with things in the incorrect spot - especially when you only show so few images that there's no way to cross reference. The sliding block with the cloth like material is also underneath its set position. WHY WOULD YOU SHOW THIS? Do you understand how frustrating this is? You are asking people to talk apart their tools and trust your guide but you are then showing as a reference incorrect disassembly images.
Nick Williams - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 32
Insgesamt: 3,782
