Zum Hauptinhalt wechseln
Black and Decker JS660 Trigger Replacement
Was du brauchst
  1. Black and Decker JS660 Trigger Replacement, Housing Disassembly: Schritt 1, Bild 1 von 2 Black and Decker JS660 Trigger Replacement, Housing Disassembly: Schritt 1, Bild 2 von 2
    • Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
  2. Black and Decker JS660 Trigger Replacement: Schritt 2, Bild 1 von 1
    • By separating the two housing halves, carefully remove the top plate.
  3. Black and Decker JS660 Trigger Replacement, Power Cord: Schritt 3, Bild 1 von 1
    • Remove the two 12.7mm phillips head screws holding the power cord in place with a PH2 Phillips head screwdriver.
  4. Black and Decker JS660 Trigger Replacement: Schritt 4, Bild 1 von 1
    • Remove the two 6.35mm flat head screws on the trigger with a 2.5 flat head screwdriver to disconnect the white and black cords.
  5. Black and Decker JS660 Trigger Replacement: Schritt 5, Bild 1 von 1
    • Gently remove the black and white cord from the trigger assembly.
  6. Black and Decker JS660 Trigger Replacement, Trigger: Schritt 6, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to press down on these tabs on the trigger assembly.
    • While the tab is depressed, the cord can be pulled out of the housing by using a moderate amount of force.
    • Each cord needs to be done separately.
  7. Black and Decker JS660 Trigger Replacement: Schritt 7, Bild 1 von 1
    • Remove pink wires from trigger assembly.
Abschluss
matt murray
682 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 22-9, Maness Winter 2017 Mitglied von Cal Poly, Team 22-9, Maness Winter 2017
CPSU-MANESS-W17S22G9
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 1,434
