Zum Hauptinhalt wechseln
Black and Decker LDX172C LED Power Indicator Replacement
Was du brauchst
  1. Black and Decker LDX172C LED Power Indicator Replacement, LED Power Indicator: Schritt 1, Bild 1 von 1
    • Before beginning, make sure the motor direction switch is in the neutral position.
    • Place the drill on the work surface with the chuck facing downward. Locate and remove the two #2 X 10mm Phillips screws located right of the motor.
  2. Black and Decker LDX172C LED Power Indicator Replacement: Schritt 2, Bild 1 von 1
    • Rotate the drill to it's left side - the chuck should be facing rightward. Locate and remove the eight #2 X 5mm Phillips fasteners from the body of the drill.
  3. Black and Decker LDX172C LED Power Indicator Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the right half of the body from the drill.
    • The trigger mechanism is spring loaded and may eject from the drill when the body is removed.
    • Locate the LED power indicator located just above the battery pack.
  4. Black and Decker LDX172C LED Power Indicator Replacement: Schritt 4, Bild 1 von 2 Black and Decker LDX172C LED Power Indicator Replacement: Schritt 4, Bild 2 von 2
    • The LED is located on a small surface mount circuit board that easily slides out of its mounting location.
    • The LED is removed by freeing the solder joints on the bottom side of the circuit board.
    • Place the new LED through the same holes and re-solder it.
    • To reassemble repeat directions in reverse order.
Abschluss
Casey
260 Reputation
2 Anleitungen geschrieben
IUPUI, Team 3-3, Wilson Spring 2016 Mitglied von IUPUI, Team 3-3, Wilson Spring 2016
IUPUI-WILSON-S16S3G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 230
