Zum Hauptinhalt wechseln
Black and Decker LDX172C Trigger Switch Replacement
Was du brauchst
  1. Black and Decker LDX172C Trigger Switch Replacement, Trigger Switch: Schritt 1, Bild 1 von 1
    • Before beginning, make sure the motor direction switch is in the neutral position.
    • Place the drill on the work surface with the chuck facing downward. Locate and remove the two #2 X 10mm Phillips screws located right of the motor.
  2. Black and Decker LDX172C Trigger Switch Replacement: Schritt 2, Bild 1 von 1
    • Rotate the drill to it's left side - the chuck should be facing to the right. Locate and remove the eight #2 X 5mm Phillips fasteners from the body of the drill.
  3. Black and Decker LDX172C Trigger Switch Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the right half of the body from the drill.
    • The trigger mechanism is spring loaded and may eject from the drill when the body is removed.
  4. Black and Decker LDX172C Trigger Switch Replacement: Schritt 4, Bild 1 von 3 Black and Decker LDX172C Trigger Switch Replacement: Schritt 4, Bild 2 von 3 Black and Decker LDX172C Trigger Switch Replacement: Schritt 4, Bild 3 von 3
    • Remove trigger from drill by pulling the mechanism directly up off the holding pins.
    • The leads from the switch are removed by using a heating the solder until they come free.
    • Re-solder the leads to the new switch.
    • Repeat directions in reverse to reassemble.
Abschluss
IUPUI, Team 3-3, Wilson Spring 2016 Mitglied von IUPUI, Team 3-3, Wilson Spring 2016
IUPUI-WILSON-S16S3G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 52
Insgesamt: 3,306
