Was du brauchst
To take off the nozzle, filter, and catch bowl first start off by pushing in the button identified with a red square and twist that part of the device toward the handle portion of the vacuum and it should click and pop off the chassis.
Once the nozzle, filter and dust bowl have been removed each part can be removed from the nozzle section of the device.
Once you have successfully unscrewed the five screws holding the cover on you should be able to take the cover off.
Remove the L-shaped plastic hook.
Once the L shaped hook has been removed the motor will easily fall out of place.
Once the motor has been removed from its home the two wires that are giving it power can easily be removed by pulling on them carefully.
This will then allow for you to replace the motor.
