Zum Hauptinhalt wechseln
Black and Decker PHV1810 Motor Replacement
Was du brauchst
  1. Black and Decker PHV1810 Motor Replacement, Nozzle, Filter, and Catch Bowl: Schritt 1, Bild 1 von 2 Black and Decker PHV1810 Motor Replacement, Nozzle, Filter, and Catch Bowl: Schritt 1, Bild 2 von 2
    • To take off the nozzle, filter, and catch bowl first start off by pushing in the button identified with a red square and twist that part of the device toward the handle portion of the vacuum and it should click and pop off the chassis.
  2. Black and Decker PHV1810 Motor Replacement: Schritt 2, Bild 1 von 2 Black and Decker PHV1810 Motor Replacement: Schritt 2, Bild 2 von 2
    • Once the nozzle, filter and dust bowl have been removed each part can be removed from the nozzle section of the device.
  3. Black and Decker PHV1810 Motor Replacement, Motor: Schritt 3, Bild 1 von 2 Black and Decker PHV1810 Motor Replacement, Motor: Schritt 3, Bild 2 von 2
    • Remove the three screws.
  4. Black and Decker PHV1810 Motor Replacement: Schritt 4, Bild 1 von 2 Black and Decker PHV1810 Motor Replacement: Schritt 4, Bild 2 von 2
    • Flip the hand vac over and remove two screws.
  5. Black and Decker PHV1810 Motor Replacement: Schritt 5, Bild 1 von 3 Black and Decker PHV1810 Motor Replacement: Schritt 5, Bild 2 von 3 Black and Decker PHV1810 Motor Replacement: Schritt 5, Bild 3 von 3
    • Once you have successfully unscrewed the five screws holding the cover on you should be able to take the cover off.
    • Remove the L-shaped plastic hook.
    • Once the L shaped hook has been removed the motor will easily fall out of place.
    • Once the motor has been removed from its home the two wires that are giving it power can easily be removed by pulling on them carefully.
    • This will then allow for you to replace the motor.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 422
