Einleitung
Use this guide to replace a faulty Black and Decker Pivot MAX (Model BDH2000PL) Motor.
The motor is responsible for rotating a fan which creates suction. The motor is the only component that causes motion while running and thus it is the only source of producing any potential noise issues. If the motor is making unusual noise, then it probably has a bad bearing or a damaged impeller. If your device is fully charged and turns on but does not run at all, check for any potential clogs. If nothing is clogged, the motor is likely the issue.
It is recommended that before replacing the motor, ensure the battery and internal wiring is not the damaged. If needed, follow this link to find instruction for replacing the battery. If everything looks fine and the device still does not run, follow this guide to replace the motor.
Make sure to power off your device and disconnect from any external power source prior to beginning this guide.
Was du brauchst
Press in and hold the release button.
Rotate the dust filter chamber counter-clockwise.
Remove the dust filter chamber.
Remove the two 10 mm screws from the motor casing with a Phillips #1 screwdriver.
Disconnect the quick connect wire harness that connects the motor and battery located in the battery storage compartment.
Remove the handle cover by removing the three PH1 20mm screws
Lift the motor casing from the outer shell of the vacuum by pulling up on the motor casing away from the outer shell.
Turn over the motor casing and locate the fan disc underneath where the motor was.
Insert one metal spudger underneath the fan disc located on the opposite side of the motor.
Remove the two 20mm Phillips #1 screws from the bottom of the motor under the fan disc.
Eine weitere Person hat diese Anleitung absolviert.
3 Kommentare
Unbelievable! They sell a replacement motor but not replacement batteries! Wow!
Can you provide a link to the exact replacement motor part?
