Einleitung
This guide is to replace the pivot lock button located in handle of the Black and Decker Pivot Max. No special tools are necessary, only a phillips screw driver is needed for this replacement.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Press in and hold the release button.
    • Press in and hold the release button.
    • Rotate the dust filter chamber counter-clockwise.
    • Remove the dust filter chamber.
  2. Remove the two 10 mm PH1 screws with the screw driver.
    • Remove the two 10 mm PH1 screws with the screw driver.
    • Pull the battery cover up and then slide away from the motor to remove.
    • Remove the battery unit by pulling it out of the main body.
    • Disconnect the quick connect
    • Remove the handle cover by removing the three PH1 20mm screws
    • Pull out the pivot lock button
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Jesse Sipes
Mitglied seit 06.11.2017
267 Reputation
2 Anleitungen geschrieben
IUPUI, Team S5-G6, Baechle Fall 2017 Mitglied von IUPUI, Team S5-G6, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G6
3 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 45
Insgesamt: 531
