Einleitung
The pivot button may need to be installed if problems such as jamming of the button occur. This guide will outline how to install the pivot button on the Black and Decker Pivot Plus PD600.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the screw located on the opposite side of the black half of the button with the lock symbol with the Phillips #1 screwdriver. Remove the screw located on the opposite side of the black half of the button with the lock symbol with the Phillips #1 screwdriver.
    • Remove the screw located on the opposite side of the black half of the button with the lock symbol with the Phillips #1 screwdriver.
  2. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. After the screw is removed, take off both sides of the button. You will be left with 3 pieces. Two halves of the button (a black piece with a lock on the front, and a circular orange piece) will be left over along with a spring.
    • After the screw is removed, take off both sides of the button.
    • You will be left with 3 pieces. Two halves of the button (a black piece with a lock on the front, and a circular orange piece) will be left over along with a spring.
Abschluss
Ryan Angelich
101 Reputation
1 Anleitung geschrieben
Cal Poly, Team 4-15, Maness Spring 2013 Mitglied von Cal Poly, Team 4-15, Maness Spring 2013
CPSU-MANESS-S13S4G15
5 Mitglieder
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 743
