Einleitung
If you are having battery problems and need to replace yours, this is the guide that will show you the simple steps to access and replace your Black and Decker drill battery.
Was du brauchst
Detach the battery unit from the drill by pressing down on the battery release button and pulling the battery towards you.
Now that the battery component is detached, remove the 4 screws indicated [16mm].
Remove each screw with the T10 Torx Security Bit Screwdriver by turning counterclockwise.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
I have a CD 9600 Type 3 with a B&D PS120 pack. are there any replacement packs available? Thanks!
