Einleitung
This guide will help repair the spring in your toaster oven door. If your door is squeaky or not opening/closing properly, this will help fix that problem. Even though this guide only has a couple steps, you must be careful when pulling the spring and twisting it. This guide is best done when using needle nose pliers.
Was du brauchst
Remove the six 9.5mm screws on the back panel using a #2 Phillips screwdriver.
Remove the two 13mm screws, located between the feet on the bottom of the cover, using a Torx T15 screw driver.
Using the metal spudger, carefully pry out the rubber base on each foot to access the screws.
Remove the back cover by gently pulling the sides of the cover apart from the rest of the oven. Then, tilt the cover towards the face and pull back at an upward angle. The cover should slide right off.
With the needle nose pliers, grasp the hook of the rear spring as close as you can to the coils. Stretch the spring back and, with a twisting motion, pull the hook out of its catch.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
Where did you find the replacement spring?
Pupule Pupule: I would suggest looking at an Ace Hardware for that spring. I believe the have a good selection of those in the drawers near the bolts. Some Home Depot’s may have them too … if they are in stock. Good Luck
John -
Does any one know what that black screw or bolt is on the back of the device? I got a different model but also have that bolt. It only seems to hold a small screw on the inside. I wonder why this part sticks out like that and what its for
